I have tried to get onto the 400 forum with no luck, this has happened just recently, I can use the other forums Is Rx Gs etc.but not the 400,a Msg keeps coming up saying your "Topic Filter Settings are Invalid" has anyone on here had this problem if so how did you fix it?
Cheers james
You might find that you can sort it here. On the bar at the top of the page entitled "The Community", look to the far right hand side you will see a Search box together with a magnifying glass and the a gear wheel. click on the gear wheel and have a look at all the options in there are correct. Mike.
