Cooling Panel Fitting
DaveEllen
Looking to fit Fargo's cooling panel & it doesnt fit.
The problem appears to be the catch you use to release the bonnet. The slot for that doeant appear big enough.
Before I start cutting I though I'd ask if this area of the car changed from Aug 1999 ?
Ta
I couldn't fit mine either, some holes didn't line up and if I tightned it up with the holes that did line up, then the whole panel buckled up
So I had a little tantrum and threw it across the garden :whistling::whistling:
Sorry Dave i meant to ring you up,, i spoke to SteveAudio and his lex is an early 2000 not a 99 as i thought. anyways he had not fitted his yet as he is busy with building work at home.
The panels were a direct copy of the cusco one i got from SiSkippy, ther was even an extra slot put in because it was unclear if the one on the cusco should have been there or not..
TO get mine to fit i had to undo slip it under the front grill as not doing so give you the problem that Chris had of the panel warping wjen bolts were tightened.
hope this helps. let me know.
Done it.........
Uploading pics........
Secret was undoing the grille screws (5) which allowed some flexing and it went in easy peasy.
The extra hole Fargo put in doesnt align but I'll either enlarge it (bees ***** out) or put my TDi commision plate there.
Chris - try what I did and it'll slip straight in as the bishop said to the alter boy :blush:
I think I'm gonna order a Cusco one at some point, and possibly see if Mick can paint it red.
Chris,
Twill fit..............just needs some wiggling............
bring it to the east anglian meet..................
will fit it for free...........
if not we can have a ceremonial crushing :whistling:
