new blubs in still not working cant find fuse all other lights working any help ta
Please don't shoot me down in flames but have you done any work on the car recently that could have dislodged a wire or similar? Mike.
Have you used LED replacement bulbs ?
It's my understanding that they require the correct polarity of connection. Try turning the bulb around in its socket. Worth a go !
I don't have the service manual for an IS200 but usually the numberplate lighting is fed off the rear tail lights. I would trace the wiring back from the numberplate lights to the next connection point,usually a multiplug and socket between the rear of the boot and the wheel arch.
If anyone does have a wiring diagram I would be happy to interpret it.
The IS200 is the same, wired in parallel to the main rear light cluster at a junction connector in the left hand side quarter panel. There is no separate fuse.
cheers everbody bad connecters got them working getting new LED to fit later
