Reversing my car into the garage the other day and the parking sensor beeping started to break down until no sound at all.
I have switched the boot switch on and off a few times and also cleaned the bumper sensors to no avail so I'm at bit stuck on where to look next, can anyone with a bit knowledge point me in the right direction please?
This might help, an old post from Bash.
If they are the OEM type the beeper/speaker is located under the NS C pillar trim. The volume control is located just up from where the jack is. You could also check under the rear bumper as one of the wires may have come loose. Mine are the Toyota Denso OEM type and there are 4 sensors fitted.I had this problem a few weeks ago, an intermittent beep, thought the one of the sensors was goosed,had a look under the bumper and found one of the wires disconnected.
Thanks Ian, I'll do some investigating based on your/Bash's suggestions.
No problem Barney, hope you find the fault.
