You've done the hard ones as the dryer thingy is the worst as it gets all the road gunge. If they're loose then you should not fret ...but be careful...sods law.... and all that. The bulk head ones came out easily on mine. That snapped head is off one of the front ones. The shank of the bolt through the fitting is the problem and after I did mine I thought it would be easier to cut the heads off and gently prise off the fittings which would leave a good bit of the bolt sticking out to grip and ease out. Best of luck but I think you're well on the way. Don't forget to grease every thing on reassembly.
