Hi, I'm attempting to change one of my front wheel bearings. I'm aware that I need to get the old one pressed out and the new one pressed back in, but has anyone done one? What's involve? Thanks
You will be hard pressed to do this job without the correct equipment ;Bearing extractor and bearing press ,these are items carried in workshops and to that end it would be a lot easier and safer if you took it to a garage to have the job done.
It does not have to be Lexus , a reputable independant will be more than happy to do the work.
You will need wheel bearing + inner and outer simerring (seal) and whilst you at it you might change the brake dust cover too (unless it is not rotten).
  • 4 months later...
I'm about to replace a front wheel bearing on my ls400 1999 can you tell me the torque setting for the retain nut?
