Seems like I got the basics in the title, after a weeks holiday I came back to a flat Battery, it is 4 years old, so perhaps past its best, but I investigated and there is a 140ma drain with the car locked and alarmed, and left for 20 minutes with the bonnet lock closed with a screwdriver, but the bonnet up.
Pulling fuses makes no difference except the OBD fuse, which drops the drain to a more reasonable 50ma.
I also get a few beeps from somewhere in the engine compartment when I pull this fuse.
So what is on the other end of the OBD fuse? I assume an OBD cpu, I will start looking this up, but anyone who has been here before, I'd be glad of any assistance
Have you something connected to OBD plug ?
That's such a good question I went out and double checked, but no, nothing connected. I do have LPG, I wonder if that's got anything to do with it.
Checked again this morning and the drain is only 80ma, still a bit high
Bit of a long shot, but do you have a USB or similar charging cable connected via the cigarette lighter socket? I had a big current leak from one of these even when the cable wasn't connected to anything, just plugged in at the supply end. I guess I'm thinking that the OBD and cigarette lighter might be on the same circuit....? Sorry if it's a red herring!
I usually do, but not at the moment, and the cig lighters are wired to be on with ign. I do have a Parrot hands-free kit, wired into the amp under the seat
attached PDF is for 96 model. Check page 4 (79)
7. 5A / OBD- II
IG1 connector = COWL WIRE AND COWL NO. 2 WIRE (NEAR THE INSTRUMENT PANEL J/B)
Brilliant stuff, so that fuse feeds the OBD connector, but when I unplug it , something beeps a complaint, so it does other stuff too, or its shorted to something. I will chase this IG1 connector
