Retracts 400h Auto Gearbox
DannyF
Hi I've brought a lexis rx 400h today and was wondering what the automatic gear B was, the others P,N,D and R are all self explanatory but not sure about B
Thanks in advance
Brake as in engine braking when going down hill. It increases the amount power going through the generators and charges the hybrid more.
And welcome :)
you can use it all the time but it isn't recommended. It will give you worse economy as the extra load isn't just from generators, it will turn over the petrol engine, without injecting fuel or sparking the plugs, which is just wasting energy.
The function has been incorrectly explained by many Toyota and Lexus sales people as a way to recharge batteries faster - this is incorrect and not what it is designed to do.
Thanks Colin, so is it really just for going down hill?
It is really only used for going down steep hills, especially when towing. It avoids overheating the brakes it you are constantly on them to stop the car accelerating away from you.
Shift lock is when the Battery is flat and you need to move out of park and into neutral to move the vehicle. There is an electric solenoid which activates when you press the brake pedal to allow the gear lever to move out of park (a safety feature to make sure you have your foot on the brake when you select a gear). If your Battery was flat then the solenoid wouldn't be able to operate.
