I have not done any research as to what this is yet - the forum is my first port of call before doing some digging.
Got in car after work today at 5pm - sat parked up since 9 this morning. Noticed the dash 'disco lights'
Check VSC / Engine and warning triangle.
Code reads as P2714 - pressure control solenoid performance or stuck off ...
Car drives as it should as drove 10 miles home. Question is .... what is this fault? Location of the part and any information to resolve it?
Anyone had this fault reported before?
thanks
so ... some digging has revealed that its either going to be an expensive repair or an instance that the error has been thrown up as a glitch of the system.
The part, if that's the issue, will cost around £400 (parts and associated bits, oil etc...) but labour when added, I expect will be around £400 as its a diagnostic investigation is done first of a few parts first and then part replacement.
I have also read that it could be due a dealer remap? Anyone heard of this being done or had done on theirs? Apparently this if FOC and clears the fault?
Also another other option is to clear the code and pray its just a glitch thrown up by the system - I have read that water and condensation can cause this on the solenoid and throws up the fault but clears and its fine after.
The OBD scanner allows me to reset the fault code which I have done as the first option so I will monitor it over the next week.
50 miles on after re-setting the fault and it has not re-appeared
Hoping for the best ..
