As the tag states when cleaning car yesterday seems to be a bit of play in the lights, is this common or should i
investigate further its both of them. Are they easy to get at does the black cover give any access or do i need to be underneath.
The lights are secured by one bolt into a bracket, so a bit of play is well possible if you push on the lamp glass. One of mine was broken out of its bracket, I suspect by someone being too heavy handed in trying to remove the bulb holder to change the bulb. (The bulb holder can get quite stuck into its location after a period of time). I fixed the light unit with Araldite.
The hatch on the nearside gives limited access. To get at the offside one you have to go in by disengaging the wing liner - that can be done by turning the wheel to full left lock, then undoing the clips securing the liner. Observe carefully how the clips, liner and wing edge relate to each other - it isn't necessarily obvious when you come to reassembly. The clips disengage with a quarter turn. Be careful in distorting the wing liner which you have to do to get to the inner area.
Hope that helps!
