Sat Nav Switching Map Configurations
evochka
I did step by step like in owners manual but cant change from dual map screen to single one. and to set compass as well. now on my mail display 2 maps so bad((( how to set single map? thanks
Even when you work it out its likely you will forget as its so intuitive. Dual to single is in the settings Option which is one of the many you select ie HOME, POSTCODE etc. Sorry I am not in the car right now. For the compass once you get the pointer on the compass click on the wheel to select different modes.
