Hi
Anyone know how o remove doorpanel driveside. My Lexus runs great everything woorks but i think windows are slow and i want to
oil windows system up. Anyone may hawe done this job. My ls400 has 11.0000 miles
Gunnar
Sweden
This may help.
http://www.lexls.com/tutorials/body/fdoorpanel.html
You may not have to remove the panels just lubricate the window channels but be cautious using silicon spray on the felt window channels do not get it on the glass as it is almost impossible to remove, I've heard graphite power makes a good lubricant.
The window edges run only within the guides on the frame of the window and as Steve says there is no need to access the inside of the door to lubricate .
It is a fair bit of work getting in and you would be destroying the seal that protects the workings within the door to no advantage.
I had a 90 mark 1 and the windows did slow down on mine over the years as the window guides harden up with age ,a bit like my arteries.
Follow Steves advice it will solve the problem
