Came from dropping off Neibour i had window down and heard rattle from back I thought something serious but on inspection when i got home it was the rear silencer Heat shield hanging off
I helped it off and the holes have corroded bigger and was ready for falling off
The question will it be ok to run without it or do i need to replace it
TIA
Robert
had the same problem. used big washers.
unscrewed the old retainers using pliers. they are made of
aluminium.
fiddly job - had jack up the car on a side i'm working on and
unhook the exhaust at the very back under bumper.
couple months ago i've done it. seems to be fine.
both sides fallen off on mine - so check.
regards,
Giedrius
Thanks for that Giedrius
I got local garage to put some large washers like you said and all done charged me 15 pound
I did price one up at Lexus £64 for a peice of bacofoil good god whats it coming to, how they could justify that is beyond me
robert
