Pretty sure they are standard on the SE-L
They will illuminate at night / in the dark (when the doors open - not too sure if they come on when the lights are on and the doors open?) but not to the point they illuminate the car.
Only standard on all SE-L models. IIRC the ISF does not come with them either, unless they were fitted to the later models. Colour changed from blue to white on the 09MY models. They can be retrofitted. I know a member on here removed them from his SE-L and fitted them to his ISF a while back. I think he found that the wiring loom was present on one side but not the other for some reason.
