Hi all
Just got myself a set of TRD skirts.
Look quite simple to fit; factory screws front and rear and clearly a fitting from underneath.
Does anyone know what the fitting for the underside is?
I would like to fit them as they should be, but cannot see anything underneath my car to attach the skirt to.
Is it a plastic push in clip or some sort of screw?
Can anyone show a picture or a link for the lower fitting?
I believe there are 5 per side.
Thanks!
There isn't,you will need to drill some holes(which I do not personally recommend)and for the bit that runs along the sills double sided tape.
Can you not use tigerseal for the underside, sets like concrete would just need holding till set. Also would be a perfect seal.
I would tiger seal them on, myself. Unless you plan to remove them for any reason, of course
Cheers guys
I just wanted them fitted as they were intended to be if I'm honest.
I would like them to look as though they were always supposed to have been there.
Also, anyone know where to get the little trim gaskets that run along the leading edge of the skirt?
My dealer says they are no longer available....
Hi, what did you end up doing with regards to the sideskirt gasket/seal?
Mine have perished so wanting to refit but cannot for the life of me find any replacements.
