Having a small problem fitting one of these cheaper wiper blades as the design entails clipping a blade cover over the arm. Fine on passenger side of course,but what I need to know is that if ALL LS400's have this strange twin arm arrangement as standard please. This will help my case with the seller. Thanks.
post-37664-0-07312300-1434195941_thumb.j
Typical. Just after I posted this,the seller offered a full refund as they wrongly listed the drivers side blade and can't supply one to fit my LS. And they don't want the blades back. Bonus. Now,back to Bosch....
By the way the picture shows the 'old' Bosch,not the new blade.
my mark 3 and 4 both had that pantograph set up - you need the wipers which fit onto hook arms without the cover
If you go for the cheap 'aero' type blades, it's very easy to neatly modify the plastic cover so that they fit the driver's side. They're really cheap blades but they work perfectly well. With regular use they will only last about 15 months though.
Wipers that WILL fit 1991 Mk1 LS400 with "funny" side fixings - Aero-type flat blades from FleaBay 290326658647 (autoperformanceonline). Not dear, fit easily, smooth as silk, even in misty rain! Don't know how long they will last, but am buying another pair in case!
