Hi I'm new to the forum I have lost my key and I am not sure of what key to order. I have a 2010 is 250 f sport and wondering if anybody knows wat key fob I will need. Thanks
If you have the master key you could try Timpsons as they can transfer the info from one to another but I am unsure if it will work with these types of keys .. or a good locksmith key cutter ...
No harm in trying
Let us know how you get on ...
If you have a brand new key, it is possible to program it to the car. It's not that difficult but does require a subscription to the lexus technical software which is expensive, and not all garages/locksmiths might have it. The software can also deactivate lost keys.
However, you must have a working, programmed key to do this. The programming process requires an already programmed key before it can be started.
Second-hand keys cannot be re-programmed to a different car.
If you've lost all your keys, then you have a BIG problem.
I've got somebody coming out tomorrow with a brand new key they have quoted me £220. Hope this works and thanks for the replies, will let you know how I get on
Don't know if it's true or not but I was told it would cost about £2000 if you've lost both keys.
Fact or fiction?
Probably true, as it would mean replacing the ECU, security unit and door locks.
the guy who came out to do the key had brought the wrong key so hes coming back tommorow with the right key to try it, will let use know how it goes, and he said it will be £220 for evrything
Sorry for the late reply n yes got it done everything worked as is should, ended up being £220 but I'm happy it has been sorted now.
I'm also getting a spare made just incas it happens again haha thanks for the replies toffee pie
Just to recap then (because this is not what I expected) you lost both keys and was able to to get one new key programmed for £220
And, who did you use for this service?
Haha yes that's the full story, and not sure of the company name who did it but I've got the number.
He brought a key out 1st but was the wrong key ant then brought 1 back few days later and it works no problem
Will post number if youse think it could be useful
Still waiting.
