Display Always Reverts To "set Up"
Hi all, I am new here after just becoming the proud owner of a 2010 Rx 450h. My first Lexus was a 1999 IS200 that I sold in 2001 so I have been Lexus less for a number of years.
Anyway, I have spent some time setting everything up with audio, Bluetooth and so on, and there is one thing that I find a little weird. With the exception of the map display, the screen always reverts to the set up menu after about 30 seconds.
E.g. If I select "audio", to display information about the currently selected source, such as track information while streaming via Bluetooth, that screen only stays put for 30 seconds and then I get the set up screen again.
I cannot imagine this is the intended behavior. Is there a setting somewhere that I have missed?
Sent from my D5503 using Tapatalk
Welcome :)
Typically under general settings there is an option for auto screen change. If this is set to on then when you select audio or climate screens, after 20 seconds of no use the screen will revert back to the previous screen, for example the map view or trip information.
