Gs300 Mk2 Replacing Radio
the radio in my gs300 dosnt work and I hate not having a radio in the car.now ive been told that I cant just get one out of a scrap car as they are coded to the car now fitting a normal radio looks a nightmare so any thoughts on how to do it?
They aren't coded to the car. The only issue is if someone has set the security code. It is user defined, not a set value. If it has been set, "SEC" will briefly show on the display when powered up. Best to check that before disconnecting in the donor car.
When you say the radio doesn't work does it display the tuning mode and search for stations?
Reason I ask is with the rest working it could be a problem with the aeriel which I would suggest checking before replacing the head unit to find you have the same problem.
steve
someone has modded it so you can plug a phone in to a aux socket plug phone in and the socket works but the guy I had it off says theres a dry joint
that needs solder.took it to a radio place and they wont even look at it as someones messed with it.
and my phone dosnt have a radio on it !
