Right guys having a bit of a night mare trying to fit a parrot system to my gs300 it's one with the touch screen. No one seems to be able to be able to find out what the correct lead is. So if anyone knows the lead I need that would be a great help.
If not I'm in the middle of converting an audio lead and got it print much there other than when the parrot is up and running the screen just fades and you can't use it. Could do with a wiring diagram for the car stereo if anyone has them as I can then finish this conversion loom off.
Or if anyone has any other info from fitting a parrot to there car please help :)
