Can Anyone Help Me ?
zeppelin
Hello and welcome to the LOC.
How did you test the sender unit? The fuel pump has nothing to do with the fuel gauge.
Disconnect the single wire from the sender unit and with the ignition turned on the fuel gauge should read empty, connect the wire to chassis/earth and the gauge should read full. If this happens the gauge is working correctly and the fault lies with the sender unit. If not the fault is either the gauge or the wiring from the sender unit to it.
