Hi guys,
Need advice regarding a service I need to do on my car. I"m not sure if I should just do an oil-change, or the whole 9 yards. The car is a 2000 model IS200 which I bought in April 2013, quick history since I have the car.
April 2013 (53000 miles)
Bought the car and did the following
Cambelt replacement
Spark Plugs
New Oil + oil pfilter
Petrol Filter
Air Filter
Brakes
Shocks
April 2014 (57200 Miles)
Oil Change + Oil Filter
New Coil Packs (one of the coil packs was faulty)
Now (60200 Miles)
Do I just need to change oil + oil filter again or should I change the petrol filter, air filer, spark plugs, since they were last changed 2 years ago (and 7000 miles ago)?
I need advice on this one cos I get the Lexus Dealer to do my maintenance and its quite costly!
I think I will change the oil + oil filter and air filter only.
I will check them too:
Check AT oil if your is AUTO transmission.
Check engine coolant , replace it every 3 years
Hi Yuen,
Thank you very much for the response - appreciated.
Hi Rich,
I noticed that Pollen/cabin filter not on your lists. But it is worth to check it too.
You can check it yourself to decide change it or not. Normally replace it every 2 years.
It located behide grove box above fan motor.
I personally change it every year because it is quite important to the air I breath when windows closed.
Hey Yuen.
Thanks a lot for that. I'll have a look for it when I clean the car this weekend..... ;-)
