My Lexus is in main dealer hospital with a yellow light warning on the dash. I have paid £190 to get it checked and the engine taken apart. I've just had a call saying the problem is that the timing chain is 'stretched' and that eventually it will go completely and needs to be replaced. The warning light will remain until it is.
I have been quoted £3,000 to fix this with a replacement timing chain. The cost of the chain is approximately £1k with £2k labour.
This seems pretty extreme to me and I would appreciate any advice as to whether this cost is reasonable or if I could get it done without the main dealer for considerably less.
Thanks in advance of your time.
I have no idea. I was surprised myself. Do you think I should kick off about it? ;-) I also don't understand how a solid metal chain can 'stretch'. I'll get a face to face chat later to discuss - so far it's just a phonecall.
I think when they say it's stretched they mean it's worn, I've read about it, but it's not a common issue and wonder what causes it
Well I've just done some research and found our that a timing chain can get worn if the engine is low on oil as it needs engine oil to keep it lubricated or type of engine oil used is not good quality engine oil
There is also something I've read about making sure small oil filters in the head get changed regulalry (not a service item). Will see if i can find it...........
