Battery Negative-Post To Chassis Connection
My IS200SE is year 2000 model.
Recently, it take me long time to find where the Battery negative-post to chassis connection.
I want to find it out to check connection good or bad.
First:
I can’t find it.
I only saw one heavy lead is connected between Battery negative-post and engine block.
Later:
I found the connection until I took the Battery and the Battery tray out.
It is a L shape metal clamped to the heavy lead to engine block on one side , bolt to the chassis on other side.
The connection is bad after 15 years. Copper wires show corrosion at clamp side and bolt rusting the other side.
I don’t like this kind of connection sharing.
It maybe for cost cutting.
Fix the connection problem:
I isolated the L shape metal clamp by electric tape.
post-53271-0-27523100-1431062145_thumb.p
Then I replace it by a new lead “25mm2 (#4 AWG) AUTOMOTIVE CABLE” connected between Battery negative-post and chassis.
After the fix, engine run better.
Also, electric window/seat etc... move faster and better.
Very happy after this :)
A good post informative post with quality picture,thank you for taking the time to share your problem.
Battery and other main earth points are very important and often overlooked as a service inspection. I subscribe to Car Mechanics magazine and in this a different car is serviced each month, the one thing common to them all is to check the earth connections and if necessary "remove,clean and refit them"
Not only can a poor earth cause poor/non start situations but with today's modern computerised cars it can glitch ECUs causing strange hard to find problems.
Colin: I don't want to restore it because I think the original connection allow electric noise / interference from the engine block to the chassis.
Steve: Thankyou for point out the important about earth points. Toyota/Lexus hiding it so well under the Battery tray :hehe:
